  3. cdlIn problems
  • Replies 13
  • Subscribers 133
  • Views 24771
cdlIn problems
archive over 18 years ago
I am trying to use the cdlIn function to import an existing cdl netlist and create a schematic.  While I was successful in getting a simple inverter to generate, when I try to import a 3 input and gate, the tool creates a multipage schematic.  It seems as if the tool cannot handle more than 2 fets per sheet.  The and gate is composed of simple primitives (8 fets).
Also, the cdlIn was not straightforward.  Even though I have my libraries attached to an existing techlib, cdlIn would not recognize the primitives within the PDK library.  I had to copy all my nfet and pfet symbols to my working directory and call them pmos and nmos, otherwise the tool created a generic symbol called mos with an empty schematic and created an empty top level schematic with ports, but no fets.
I am using version 5.1.41 on a Linux box.
Chris
Originally posted in cdnusers.org by csprice63
    That's what a Cadence rep told me today.  I just submitted an SR.  Thanks for all your help.
    Chris
    USR3 gives me same result.
    Originally posted in cdnusers.org by rairaj
    Just for the record, in case anyone is following this thread, the problem was with me using USR3.  I was able to get cdlIn using IC5141/USR5.  Yes you need a device map file.
    Chris
