  3. ERROR (SPECTRE-8390): Problem encountered in setting up...
  • Views 16884
ERROR (SPECTRE-8390): Problem encountered in setting up the mpsc front end.
admin
admin over 12 years ago
Hello World!, This is my first post in this forum.
I would appreciate some help with this issue. I'm using ADE L inside Virtuoso environment to perform some simulations, but when I press "Netlist and Run" button the simulation is not performed and shows the message:
Error found by spectre.
I have googled this kind of error but couldn't find any information about it. I have read the post in http://www.cadence.com/forums/p/27332/1327269.aspx#1327269 as well, but I think the solution described there doesn't help me because I'm not trying to run the simulation from command line.
The full log is attached.
Does anyone know a solution for this kind of error?
Thank you.
  • log.txt
  • Quek
    Quek over 12 years ago
    Hi Arthur
    Would you please try the following to see if it helps?
    a. Close ADE-L
    b. Enter the following in CIW:
    envSetVal("spectre.envOpts" "controlMode" 'string "batch")
    c. Re-open ADE-L and retry simulation.
    Best regards
    Quek
    Another thing to check is whether you have a wrapper script around spectre. Maybe this is sending the spectre simulation to a remote machine, and hence it is unable to communicate properly with the parent process. In such cases, setting the controlMode to batch as Quek has suggested makes sense. If not, you should contact customer support (although Quek's suggestion would give you a workaround in the meantime).
    You could do "which spectre" in a terminal window to check if you're using a wrapper script. If the result is from the MMSIM installation, then you're probably not using a wrapper, just our built-in wrapper script.
  • ArthurLombardi
    ArthurLombardi over 12 years ago
    Thank you for your suggestions Quek and Andrew but, a few hours after my first post, the network admin solved the problem. I don't know the details but it seems to be a DNS related issue. Now the ADE L works fine.
    I tried to answer your messages as fast as possible but, as you can see in the first post, I have experienced some problems with my account and could not log in for some days.
    Best regards, Arthur
