  3. ADExl problem with bus notation
  • Views 16936
sram8t
sram8t over 12 years ago
Running a spectre simulation from adexl I am getting this error:
Error found by spectre during circuit read-in.
    ERROR (SFE-874): "input.scs" 3633: Unexpected operator ">". Expected end of
        file or end of line.
The interesting part of scs netlist is listed below. Please note that the \ escape was applied to the netlist but not to the output signals. I don't know why.
I tried the \ escape on the "Outputs Setup" pane but then I could not check the save box. Thus, I assume I cannot enter the signals with the \ escape in the outputs setup pane. How can I getaround that problem?
IWRLINEDEC_TOP (WADR_IN_0 WADR_IN_1 WADR_IN_2 WADR_IN_3 WA0C_DEC \
        WAC_UNUSED_DEC\<0\> WAC_UNUSED_DEC\<1\> WAC_UNUSED_DEC\<2\> \
        WAC_UNUSED_DEC\<3\> WAC_UNUSED_DEC\<4\> WAC_UNUSED_DEC\<5\> \
        WAC_UNUSED_DEC\<6\> WAC_UNUSED_DEC\<7\> WAC_UNUSED_DEC\<8\> \
        WAC_UNUSED_DEC\<9\> WAC_UNUSED_DEC\<10\> WAC_UNUSED_DEC\<11\> \
        WAC_UNUSED_DEC\<12\> WAC_UNUSED_DEC\<13\> WA15C_DEC \
        WR_AC_INT_BOT_TOPADRDEC\<0\> WR_AC_INT_BOT_TOPADRDEC\<1\> \
        WR_AC_INT_BOT_TOPADRDEC\<2\> WR_AC_INT_BOT_TOPADRDEC\<3\> \
        WR_AC_INT_N_BOT_TOPADRDEC\<0\> WR_AC_INT_N_BOT_TOPADRDEC\<1\> \
        WR_AC_INT_N_BOT_TOPADRDEC\<2\> WR_AC_INT_N_BOT_TOPADRDEC\<3\> \
        RADR_IN_0 LBIST_EN_DC VDD VSS) CAB_C8T_ADRDEC16C_WR
simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=85 \
    tnom=25 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
    checklimitdest=psf
tran tran stop=1n errpreset=moderate write="spectre.ic" \
    writefinal="spectre.fc" annotate=status maxiters=5
subckts info what=subckts  where=rawfile
save NCLK Ilsdrv/wwl_wwldrv_w0 Ilsdrv/wwl_wwldrv_w15 Ilsdrv/wwl_wwldrv_wN \
    Icore/RWL_B0_WN<0> Icore/RWL_BN_W0<0> Icore/RWL_B0_W0<0> \
    Icore/RWL_BN_WN<0> Icore/RWL_B0_WN<31> Icore/RWL_BN_W0<31> \
    Icore/RWL_B0_W0<31> Icore/RWL_BN_WN<31> Icore/RWL_NEAR_W0 \
    Icore/RWL_NEAR_W15 Icore/RWL_NEAR_WN Icore/WWL_B0_WN<0> \
    Icore/WWL_BN_W0<0> Icore/WWL_B0_W0<0> Icore/WWL_BN_WN<0> \
    Icore/WWL_B0_WN<31> Icore/WWL_BN_W0<31> Icore/WWL_B0_W0<31> \
    Icore/WWL_BN_WN<31> Icore/WWL_NEAR_W0 Icore/WWL_NEAR_W15 \
    Icore/WWL_NEAR_WN
     Which subversion of virtuoso are you using? (Help->About in the CIW will tell you this, or typing getVersion(t) in the CIW)
    In addition, what do you get if you type:
    envGetVal("asimenv" "mappingMode")
    in the CIW?
  • sram8t
    Andrew,
    I have ICADV12.1-64b.500.6
    envGetVal("asimenv" "mappingMode") -> "nmp"
    Joachim
  • sram8t
    Got further with the problem:
    the output signal was missing the preceeding / on the "Outputs Setup" pane.
    e.g.   Icore/RWL_B0_WN<0>
    With the signal name changed to  /Icore/RWL_B0_WN<0> the simulation ran to completion.
    The input.scs file now has it in the save statement as Icore.RWL_B0_WN\<0\>
     But now, when double clicking on the output I get this message:
    ERROR (WIA-1006): Unable to plot expression <VT("/Icore/RWL_B0_WN<0>" .....
    *Warning* Wave1 is not a waveform object that can be displayed and
              will be DELETED automatically.
