  3. virtuoso possible outputs in IC610
  • Views 14736
jagdev
jagdev over 12 years ago
needed some help in using cadence IC610. Is there an provision in the Analog design environment or else where in virtuoso which directly gives the below values-
power consumption
capacitance
area occupied
propagation delay
for example if the above are to be calculated for a cmos NAND circuit.
regards
    Not really. The first, second and fourth could be calculated from the results of suitable simulations, whereas the area occupied would have to be some estimate based on the size of the transistors.
