  3. Markingnet throught tilenot layers
  • Views 15149
bharath2k4
bharath2k4 over 12 years ago
I am trying to marknet which is connected to critical block placed under tilenot layer. When i mark this, It is highlighting everything because of TileNot layer. Is there a way to marknet inside tilenot layer. I know, i can use Stop layer to stop it just before tilenot layer, but my requirement is to mark net inside tilenot layers also. I am using cadence IC616
Bharath.
    What's a "tilenot" layer?
  • Gerald08
    Gerald08 over 11 years ago
    Hi Bharath,
    I have once experience your problem.. I'm assuming "tilenot" is a purpose layer of metalx layer right?..
    if this is the case, by default marknet will automatically trace everything on the metalx layer..
    You should properly define the layer you want to trace and its layer "purpose"..
    On the "MarkNet" option form.. go "Via Layers" tab..
    Then manually define  the tracelayers to avoid tracing the tilenot layer
    Example on the Add via layers
    Layer1  metal1 drawing
    vialayer via1 drawing
    layer2 metal2 drawing
    then press Add
    do this up to the last layer you want to trace.
    Ghe
