  3. resources for beginners with regards to analog layout automation...
  • Views 15182
resources for beginners with regards to analog layout automation for cadence virtuoso
auto dipper
auto dipper over 12 years ago
Hi all,
Could anyone please let me know some resources for beginners with regards to analog layout automation?
And physical verification using Cadence?
regards
    The Rapid Adoption Kits on Cadence Online Support are probably your best bet. These can be found under Resources (at the top), then Rapid Adoption Kits, then Virtuoso Custom IC and Sign-off flow. A shortcut is:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=wp;q=ProductInformation/Custom_IC_Design/ApplicationPackages/CIC_RAK_Home.htm
    There a number of relevant RAKs, but two good points to look at would be:
    • Layout Design in IC 6.1.6
    • Introduction to Connectivity-Driven Design in VLS XL
    There are quite a few other layout automation RAKs too - but start with these.
    If you are at a University, you should be able to get access either via your University program coordinator, or through Europractice (if you're a university using the Europractice scheme).
