  3. QRC extraction failure with Calibre input
  • Views 19106
Shawn Yang
Shawn Yang over 11 years ago
Hi All
When I run qrc_cmd file (content is listed at bottom), error was found and stop in pax step:
WARNING (LBMISC-215001): file 'via1' is not a flat edge file
ERROR (LBMISC-215002): it is a hierarchical edge file
I have done a clean LVS with "Flatten" setting.
Tools version:
calibre 2013.3_39.24, QRC 10.1.3-p065
My QRC extraction flow is:
1. run lvs by GUI with lvs.cmd (fab provided), and make a clean result
2. run lvs by GUI with xrc.cmd (derived from lvs.cmd, and added XRC options according to fab‘s guidance).
3. run calibre:calibre -query_input query_cmd -query svdb xrc_test
4. run:qrc -cmd qrc_cmd
qrc_cmd file content:
output_setup -temporary_directory_name qrc_output
log_file -file_name qrc_output/qrc.log
process_technology -technology_library_file "qrc_rule/QRC_28PS_1P8M_6Ic_2TMc_ALPA1_V0.5_1T/rulefiles/tech.lib" -technology_name CMAX
input_db -type calibre -directory_name query_output -run_name Design -layer_map_file query_output/Design.gds.map -device_property_value 7 -instance_property_value 6 -net_property_value 5 -library_cell_list_file qrc_rule/assura_QRC/preserveCellList.txt -hierarchy_delimiter \/ -design_cell_name test_qrc av_extracted test_qrc
output_db -type dspf
qrc.log file:
(former contents ignored)
# Run pax16 to generate capfile
pax16 -V -scf sip.cmd -M_perim_off -cgnd ${CAP_GROUND},1.0 -c \
/home/yangsy/tmp/28qrc/xrc_test/qrc_rule/QRC_28PS_1P8M_6Ic_2TMc_ALPA1_V0.5_1T/rulefiles/CMAX/qrcTechFile \
-f FOXA active poly metal1 metal2 metal3 metal4 metal5 metal6 metal7 \
metal8 alpa_inter - \
- - NET - capfile
rdpaxcmd took
0.35 user, 0.15 sys, 1.00 elapsed, 47952.0 kbytes
ERROR (LBRCXM-609): Bad return status from RCX run. 0xff00
INFO (LBRCXM-709): *****QRC terminated abnormally*****
  • Quek
    Quek over 11 years ago
    Hi Shawn
    Would you please retry the extraction using a higher version of QRC (e.g. 14.1)? It is possible that the issue has already been fixed in the latest version.
    Best regards
    Quek
  • Shawn Yang
    Thanks Quek. However, it should work according to Fab's guidance by using this version. I use command flow while the guidance provides UI one
  • Quek
    Hi Shawn
    The version provided by foundry only serves as a guideline. Sometimes customers will need to use a higher version due to tool bug, etc. The current case is most probably a bug so it would be good to switch to a higher version of QRC.
    Best regards
    Quek
  • Shawn Yang
    Hi, Quek
    I see. Thanks for your kind suggestion.
    All the best,
    Shawn
