  3. about Nest limit in cadence virtuoso platform
  • Subscribers 133
  • Views 17751
archive over 19 years ago
How do i reset the nest limit in virtuoso layout editor window after exceeding the nest limit 20.
No commands are working.
Please anybody help me out.
Ravi..
Originally posted in cdnusers.org by Ravikumar.A
    The best thing is not to let the commands get too nested in the first place. Hitting "escape" to escape out of commands is a good thing. Alternatively turn off the "repeat command" option in the options form for the editor.
    Unfortunately there's a problem where if you close the window with a nested command in action, it doesn't reset the stack (I'm not sure whether this has been fixed yet) - but I think most of the time it is down to people keep nesting functions - or nesting enter functions in their own SKILL code.
    Unfortunately if escaping doesn't help, and you're already at 20, you have to exit the DFII session to reset it.
    Originally posted in cdnusers.org by adbeckett
    I found that certain commands cause the nesting problems. Commands like createPath, move and stretch don't nest, but commands like createRuler and createRect do. To solve the problem, I changed the EF (enter function) bindkeys for these commands to look like this (assuming 'k' is the bindkey for ruler and 'r' is the bindkey for rectangle:
    hiSetBindKey("Layout" "k EF" "if(hiGetCurrentCmd(hiGetCurrentWindow()) != \"Ruler\" then leHiCreateRuler() )")
    hiSetBindKey("Layout" "r EF" "if(hiGetCurrentCmd(hiGetCurrentWindow())==\"Rectangle\" mouseAddPt() leHiCreateRect())")
    I don't know if this will show up correctly since the word "Key" is surrounded by angle brackets.
    Originally posted in cdnusers.org by dmay
    How about this (I'll try escaping the angle brackets):
    hiSetBindKey("Layout" "\k EF" "if(hiGetCurrentCmd(hiGetCurrentWindow()) != \"Ruler\" then leHiCreateRuler() )")
    hiSetBindKey("Layout" "\r EF" "if(hiGetCurrentCmd(hiGetCurrentWindow())==\"Rectangle\" mouseAddPt() leHiCreateRect())")
    If this doesn't post correctly, you'll have to look up the hiSetBindkey command to get the syntax right.
