  3. Problems with multiple veriloga modules but same terminal...
  • Views 17083
Problems with multiple veriloga modules but same terminal names for symbol in Spectre cell view
Pasupathy KR
Pasupathy KR over 11 years ago
Dear Sir,
 I have created a symbol in Cadence Spectre Schematic tool and using 'create cellview from cellview', I added a verilog-A code for that symbol  with module name L3. And in L3module, L2 is instantiated by mentioned its file path using 'include compiler directive and instantiate syntax. And in L2 , L1 is instantiated in the same way.
L3's terminals are Source, Drain, Gate, Sub. (in symbol also i maintained only these 4 terminals only)
L2's terminals are Source , Drain, Gate, Sub, CoupleNode
L1's terminals are  Source , Drain, Gate, Sub,CoupleNode
Problems :
But when I save L3, Verilog parser says errors like port order do not match. In CIW, I get errors like this : "more than one module is there in the code" and  L3 is having 4 terminals while the other module is having 5 terminals.
So i added one dummy 5th terminal for  the symbol and I did 'netlist and run' in Virtuoso ADEL. It is running successfully but NOT getting expected output .
Kindly suggest solutions for the above problems.
Note : - Product Version 6.1.5
May 2012 (for all the software tools used for this problem)
Thanks and Regards,
K.R.Pasupathy
    It's a bit hard to visualise without seeing the code you're using - although I would ask why you want to use multiple modules in the same file in Virtuoso - it doesn't quite fit the expected use model...
    Kind Regards,
  • Pasupathy KR
    Thank you for your reply Andrew.
    L1, L2 and L3 DO NOT have same functionality.
    The reason for multiple modules is that L1 has core functionality while L2 and L3 adds additional functionality to L1.
    So the design is structured hierarchically as L1-L2-L3 with L3 as the top module, which is very common when we write very lengthy code (ie) the functionality is split hierarchically to make a good design.
    Thanks & Regards,
    Pasupathy K.R
  • Pasupathy KR
    Dear Andrew,
    The problem is SOLVED now.
    Best Regards,
    Pasupathy K.R
    Glad you found that - I was about to say the same thing!
