  3. How to extract parameters in cadence?
  • Views 16675
usercad
usercad over 11 years ago
Does anyone know how to extract parameters in cadence IC 6 ?        I use a verilog a model and some parameters in verilog are not shown to the user and I want to know their values?
    Not sure what you mean by "extract parameters"? Can you please clarify your question? Maybe with an example?
  • usercad
    Thanks a lot for your reply,
    As an example : I am simulating BSIM 106 model , some parameters in the design are not showed to the user they are only found in the verilog of the model , and others are shown , Is there a way to know their values ?  when I change some model parameters these parameters( that I want to know their values )  are changed and I want  to know their change.                                                           Please tell me if my question was not obvious        Thanks in advance
  • usercad
    In other words , some set of global parameters for BSIM have to be found to fit experimental data for short and long device , I hope my question is clear , thanks
    There would need to be some attributes in the model to assist with saving operating point data if it is a VerilogA model of a compact model. The following forum post and Designer's Guide post (with comments from me) give some guidance on this:
