  3. Creating a CNTFET model in cadence using veriloga
  • Views 16938
nikita6
nikita6 over 11 years ago
I want to model a cntfet in cadence using veriloga. I used the veriloga code (nano.stanford.edu/stanford-cnfet-model-verilog). I followed these steps to create the cntfet model-
1. I created a new veriloga cell view and edited the veriloga.va by copying the code of NCNTFET_L3.va. I also added the fles NCNFET_L2.va, NCNCNT_L3.va and parameters.vams in the veriloga directory created.
2. I created a symbol from the veriloga cell view (create->cellview->from cellview).
3. Now I opened a new schematic and used this symbol to implement a simple circuit. I was not able to select from schematic for plotting the outputs and encountered the error -
ERROR (OSSHNL): Error(s) found during netlisting. The netlist may be corrupt or may not be produced at all.
To generate correct netlist, fix the errors and re-netlist.
      ...unsuccessful.
What and where could be the problem? Kindly look into this and help me out.
  • Shobhitkareer
    Shobhitkareer over 8 years ago
    Have you solved this problem?
