  3. Virtuoso installation in Ubuntu 64bit
  • Views 23983
Vigna
Vigna over 11 years ago
i have installed Virtuoso(IC615) in my Ubuntu 14.10 64bit, i have installed using installscape with (local directory option). it showed that installation has been success, but when i try to invoke virtuoso by the command ("virtuoso&"). i am not getting any error message but the same time virtuoso is not invoking rather my terminal window terminates. i dont know where i went wrong? either in my installation or something? please help me out. Thank You
    Ubuntu is not a supported platform anyway, but I can't really see why it should cause the terminal window to exit - that sounds very strange indeed.
    Not really sure how to help you - you could go to customer support to see if we can figure this out via some remote debugging - but I would in general advise that you use a supported OS distribution (RHEL or SuSE). The software is not tested on other distributions, and realistically we cannot provide support on other distributions as otherwise we'd have to install each and every flavour that is in use.
  • theopaone
    theopaone over 11 years ago
    I've had success running on Centos. It is a free Redhat clone.
