  3. streamout in batchmode
  • Replies 8
  • Views 19878
varunkumar
varunkumar over 11 years ago
Hello ,
I am trying to streamout in batch mode with the following command   (-A is my saved template file for IC 6.15.162  as we get the option in GUI to save the template file)
strmout -library 'ttest_lib' -A 'resis_test.gds' -techLib 'cmos32lp' -topCell 'resis_test' -view 'layout' -noInfo '162' -logFile 'strmOut.log' -runDir '/./'
I am getting following error on terminal
*ERROR* License "111" could not be checked out.
*WARNING* (icLic-3) Could not get license Virtuoso_Layout_Suite_L
*WARNING* (icLic-3) Could not get license Virtuoso_Layout_Suite_XL
*WARNING* (icLic-4) Could not get token capability VLS_GXL
please help in to remove the error and to streamout in batchmode.
same way if you can help me to out CDL.
Normally I am getting license in GUI mode.
  • varunkumar
    hello can anyone please answer if possible
    The error is clear - it cannot find a license.
    Maybe you have a wrapper when you run virtuoso which sets $CDS_LIC_FILE, but you don't have a wrapper when you run strmout?
    In Virtuoso, in the CIW, try typing:
    getShellEnvVar("CDS_LIC_FILE")
    and see what it reports. In the shell, try doing:
    echo $CDS_LIC_FILE
    Is it set? If not, try doing:
    setenv CDS_LIC_FILE valueReportedinCIW
    or if using ksh/bash, use:
    export CDS_LIC_FILE=valueReportedinCIW
    And then run strmout.
  • varunkumar
    Yes license environment is already set on the terminal and I can see the value with echo  command.  I want to streamout the gds and cdl database without  invoking the virtuoso .still it is not working. Am I using the correct way to streamout ?  I have used the streamout command which displayed on the CIW while doing the streamout  in GUI mode with virtuoso opened.
    If you have any alternative way of doing please suggest. My objective is to get the GDS and CDL without invoking virtuoso since sometime we need only gds and cdl to play. I have the saved template file for the GDS similar way si for CDL for particular IC version and license is also   set .
    It must be that you either don't have a free license or that there is something incorrect in the setup. If you can't get this working, you should contact http://support.cadence.com so that we can take a look at your setup
  • varunkumar
    ok ...can you suggest some alternative way to do that ??....since I can do easily by launching virtuoso ....just I wanted to learn alternative way of doing in batch...
  • varunkumar
    Any comment or I assume this post is close here...thanks in advance
    Hmm. You ignore the bit in my previous post suggesting you contact customer support and ask for another solution (for something that should work fine, and almost certainly is due to something messed up in your environment), and then chase that request about an hour later?
    This is a community forum and everyone here (including me) is a volunteer who does this in their spare time. It is NOT a substitute for customer support and anything that urgent should be directed to the support channel.
    The alternative would be to write some SKILL code which does a number of calls using xstSetValue() and then xstOutDoTranslate(). Then do "virtuoso -nograph -restore streamOutCode.il" (you may want a call to exit() at the end of the file).
    This should not be necessary and that's why I strongly suggested that you go to customer support.
    I may not be so generous next time you nag for a response in a community forum.
    Kindest Regards,
  • varunkumar
    Ok ..point taken...I regret for being desperate response since I was stucked at some point and I believed in you as a group moderator and for frequent and correct response. anyways thanks for that .. and any community work well on belief  and for nice response only...
