  3. What is the solution of issue about trannoise with PSP model...
  • Views 14891
What is the solution of issue about trannoise with PSP model?
mjlee
mjlee over 11 years ago
I have to simulate with spectre with PSP model. However we know that it can't use spectre as trannoise simulator.
I wonder whether above problem was solved in the new MMSIM version.
I can use MMSIM version- 12.1, 13.1, 11.1.
Thank you.
    You need to be using MMSIM13.1 ISR12 or later (assuming  you are using the built-in PSP models in spectre, rather than via the NXP SimKit).
    You also need to add the option noisemethod=subckt to the Analog options - if using ADE, you'd go to Simulation->Options->Analog, and then in the Misc tab, in the Additional Parameters field, enter noisemethod=subckt.
    You can pick this option in earlier versions, but if you do, the AC noise (i.e. small signal noise) simulations will be wrong - ISR12 fixes it so that it is consistent in both.
