  3. neural signal
  • Replies 18
  • Views 21910
neural signal
pratibhads2805
pratibhads2805 over 11 years ago
hi
The input to my circuit is neural signal, i want to ask that how to get neural signal input in cadence.
  • analogy
    analogy over 11 years ago
    Even if it's a neural signal, don't you have voltage-time file for the signal ? If you have voltage-time points of signal, you can use analogLib>vsource>pwl and define your signal using file or enter time-signal points.Hope it helps.
  • pratibhads2805
    thanks for you reply , can you please tell me where could i get voltage-time profile of neural signal ??
    Google? It's not something we provide as part of the software (it's a rather specific type of data, and presumably a good question for your supervisor - I'm guessing you're from an academic institution).
  • analogy
    Or you can use MATLAB to create arbitary points based on neural signal average amplitudes.
  • pratibhads2805
    hii
    what would i connect to the floating inputs if  i don't have library for unconnected option?
    I have no idea what this means. What is "library for unconnected option"? If an input is floating, nothing is connected - if something was connected, it wouldn't be floating - so it just doesn't make sense.
    You need to ask clear questions to get clear answers.
    Kindest Regards,
  • pratibhads2805
    Actually, i was trying to ask about the techniques required to terminate unused gates to ensure spurious switch does not introduce noise
  • pratibhads2805
    hii
    anyone can tell me that how to plot offset voltage vs common mode curve.
    here is a paper in which it is plotted -
    M.Hassanpourghadi,etal.,Alow-powerlow-offsetdynamiccomparatorforanalogtodigitalconverters,
    Microelectron.J(2013), http://dx.doi.org/10.1016/j.mejo.2013.11.012i
  • pratibhads2805
    hello sir,
     I've generated the voltage-time points of the neural signal using MATLAB. I've the following .txt file. Please tell is it the correct format or not??
    I am copying the data from notepad
    4.8000000e+001 6.2500000e-003
    3.2000000e+001 1.2500000e-002
    3.2000000e+001 1.8750000e-002
    3.2000000e+001 2.5000000e-002
    3.2000000e+001 3.1250000e-002
    3.2000000e+001 3.7500000e-002
    3.2000000e+001 4.3750000e-002
    3.2000000e+001 5.0000000e-002
    8.8000000e+001 5.6250000e-002
    3.2000000e+001 6.2500000e-002
    8.8000000e+001 6.8750000e-002
    3.2000000e+001 7.5000000e-002
    8.8000000e+001 8.1250000e-002
    3.2000000e+001 8.7500000e-002
    8.8000000e+001 9.3750000e-002
    3.2000000e+001 1.0000000e-001
    3.2000000e+001 1.0625000e-001
    3.2000000e+001 1.1250000e-001
    3.2000000e+001 1.1875000e-001
    3.2000000e+001 1.2500000e-001
    3.2000000e+001 1.3125000e-001
    3.2000000e+001 1.3750000e-001
    3.2000000e+001 1.4375000e-001
    3.2000000e+001 1.5000000e-001
    3.2000000e+001 1.5625000e-001
    3.2000000e+001 1.6250000e-001
    3.2000000e+001 1.6875000e-001
    3.2000000e+001 1.7500000e-001
    3.2000000e+001 1.8125000e-001
    3.2000000e+001 1.8750000e-001
    3.2000000e+001 1.9375000e-001
    3.2000000e+001 2.0000000e-001
    3.2000000e+001 2.0625000e-001
    thank u sir in advance.
    If you want to use this as a PWL (piece wise linear) vsource, then your two columns are the wrong way around. The time should be the first column and the voltage the second column.
