  3. Regarding addition of .sp file to a analogLib model
  • Views 18126
eashwar g
eashwar g over 11 years ago
i have used nmos and pmos from analogLib ..
in adexl > setup>model libraries ---- i gave path to a spice file (which i saved it as .sp file),but after simulating i get this error ,
""Error found by spectre during circuit read-in.
    ERROR (SFE-868): "input.scs" 8: Unable to open input file `/home/eashwar/Desktop/eashwar/decoder/memcell/transisitor'.
        No such file or directory."""
i tried giving same model name to the nmos4 transistor and the model name inside the textfile as nmos4
This is a small part of it
.model  nmos  nmos4 level = 54
+version = 4.0             binunit = 1               paramchk= 1               mobmod  = 0
+capmod  = 2               igcmod  = 1               igbmod  = 1               geomod  = 1
+diomod  = 1               rdsmod  = 0               rbodymod= 1               rgatemod= 1
+permod  = 1               acnqsmod= 0               trnqsmod= 0
any suggestions on how to use this  spice model file
    Clearly from the error message you either got the path to the file wrong, or the permissions are such that the file can't be opened. Given that you said you'd saved it to a ".sp" file, but the path in the error message doesn't have ".sp" in it, did you just omit the suffix?
  • eashwar g
    no i didnt omit that
    i saved it as nmos 32nm.sp
    so it was skipping the space between nmos and 32
    i figured it out and i got it
    thank u
    Generally spaces in file names are frowned upon in the UNIX world because lots of things tend to assume spaces as a delimiter rather than an integral part of a file name. So best to avoid unusual characters in filenames (stick to alphanumeric characters, underscores and dots).
  • eashwar g
    thank you sir, its really helpful
