  3. descend to new window
  • Views 17992
Karev11
Karev11 over 11 years ago
I have two questions about descend, wonder if anyone could kindly give some suggestions.
1. in cadence 615, to descend down a schematic, it always pops up a window asking whether to open new schematic in current window or new window or new tab. however, in 5141, there doesn't seem to be such feature, I wonder if open-in-new-window feature exists in 5141? if so, how?
2. for some reason,  when I try to descend down a schematic, the descend pop-up window hides in the back of current window, is there a way to have it automatically show in the front?   (actually, similar thing happens to calculator as well, I know in 615, after choosing plot , schematic window will be brought to the front right away, however, it doesn't happen at 5141, again, is it a feature that 5141 doesn't have, or it's a setting issue?
thanks!
Kevin
  • Karev11
    Just read the guideline... my current version is 5.10.41.500.6.151
  • skillUser
    skillUser over 11 years ago
    Hi Kevin,
    IC5141 doesn't have tabs for different cell views in the same window, so your next closest option is to set an environment variable to open a new window when descending (look at CIW->Options->User Preferences for the form interface), put this in your .cdsenv:
    ui setWinTraversal boolean t
    For the window/form hiding issue, this is really something that is under the control of the window system - which one are you using?  In the past I've had good experiences with FVWM (fvwm2) and it is highly configurable.
    Hope this helps!
    Lawrence.
  • Karev11
    Thanks Lawrence,
    We used X-Win32 2012 here, it allows dynamic window scaling and is generally smooth and good, except a few things like mentioned above that'll make it great if fixed.. I actually went through the whole settings/configurations etc and also its manual, there's no mentioning about any solutions to above mentioned scenarios.
    Kevin
    Kevin,
    This window behaviour is a little related to the application, but mostly due to the Window Manager, as Lawrence said. Because the IC5141 UI is based on Motif technology, and the IC61X UI is based on Qt technology, there are sometimes differences in how window managers deal with these.
    Anyway, there's no user setting in Virtuoso (in IC5141 or IC61X) to control this behaviour (the descend, yes, as Lawrence pointed out, but not the window obscuring issue).
    With KDE and Gnome this is generally related to "focus stealing prevention" settings. Not sure about X-Win32 (I've not used that for many years now).
