  3. failed to simulate veriloga in hspice : call to epvaHDLcgen...
  • Views 18114
failed to simulate veriloga in hspice : call to epvaHDLcgen failed
zongya
zongya over 11 years ago
Hi all,
I'm trying to simulate a veriloga vccs in hspice.
Here is my veriloga code for vccs:
/ VerilogA for fishy1, asl6, veriloga
`include "constants.vams"
`include "disciplines.vams"
module asl6 (p, n, ps, ns);
inout p, n, ps, ns;
electrical p, n, ps, ns;
parameter g = 1.0;
analog begin
I(p, n) <+ g * V(ps, ns);
end
endmodule
And here is the netlist:
** Generated for: hspiceD
** Generated on: Mar  6 00:53:38 2015
** Design library name: fishy1
** Design cell name: asl7
** Design view name: schematic
.hdl "/home/somnathchakr/vlsix/veriloga.va"
.vec 'vector.vec'
.include "/opt/cadence/FreePDK45/FreePDK45/ncsu_basekit/models/hspice/hspice_nom.include"
.TEMP 25.0
.OPTION
+    ARTIST=2
+    INGOLD=2
+    PARHIER=LOCAL
+    PSF=2
+    POST=1
** Library name: fishy1
** Cell name: asl7
** View name: schematic
xi0 net5 b a 0 asl6 g=1
r0 net5 b 1
.tran 1p 10n
.END
And it gives me errors like this:
libepva built by pvamgr synmake_pva_build  on Sun May 22 07:53:10 PDT 2011
HSP_HOME:   /usr/synopsys/hspice/hspice
HSP_ARCH:   linux
HSP_GCC :   /usr/synopsys/hspice/hspice/GNU/amd64/gcc-4.2.2-static/bin/gcc
HSP_GCC_VER:
Working-Dir: /home/somnathchakr/vlsix
Args:        -p hsp -t spi -f Ictest5.pvadir/pvaHDL.lis -o Ictest5.pvadir
Begin of pVA compiling on Thu Mar 12 10:28:48 2015
Parsing '/home/somnathchakr/vlsix/veriloga.va'
Parsing include file '/usr/synopsys/hspice/hspice/include/constants.vams'
Parsing include file '/usr/synopsys/hspice/hspice/include/disciplines.vams'
End of pVA compiling on Thu Mar 12 10:28:48 2015
End of build pVA DB on Thu Mar 12 10:28:48 2015
*pvaI* Module (asl6): 4 unexpanded port, 0 init, 1 behav, 1 contrib, 12/0 expr(s)
*pvaI*              0 afCount, 0 fixDIS
*pvaI* Module (asl6): generated 0 flow node(s) during compilation.
End of pVA genC on Thu Mar 12 10:28:48 2015
*pvaI* #### Total 119 line-size(s), 12 expr(s), 1 contr(s), 0 init(s), 1 behav(s), 4 port(s)
Generating Ictest5.pvadir/pvaRTL_linux.so
End of submitting pVA Ictest5.pvadir/pvaRTL.mak on Thu Mar 12 10:28:48 2015
*pvaI* system & gcc return code is 512
 **error** call to epvaHDLcgen failed.
  **error** (Ictest5.sp:23) Definition of model/subckt "asl6" is not found for the element "xi0". Please specify a defined model/subckt name.
 **warning** multiple output options specified, using post
          ***** job aborted
Parsing '/home/somnathchakr/vlsix/veriloga.va' This means it can find my .va file, and read 'constants.vams' and 'disciplines.vams' in, but the error  Definition of model/subckt "asl6" is not found for the element "xi0" means it cannot find my defined circuit?
I googled the error "call to epvaHDLcgen failed.", people said it occurs because of the directory. But my directory is correct...I mean "/home/somnathchakr/vlsix/veriloga.va" is correct. Also, I tried to delete the ".hdl" line in the netlist file and add a command line " -hdl veriloga.va " in the command. It shows me the same error.
Could anyone help me with this? Thanks in advance!
Zongya
    You might be better off asking this on a Synopsys forum rather than a Cadence forum, given that HSPICE is a Synopsys product, not a Cadence product...
  • zongya
    Alright. Thank you!
