  3. values of a cursor messed up
  • Views 15066
Karev11
Karev11 over 11 years ago
I'm using IC 5141. When I add a cursor to any waveform in the waveform viewer, x and y value for the cursor are supposed to show at the lower left section, however, mine got messed up, looks like it's showing some number, but got shifted and overlapped with other numbers/characters etc. I  restarted cadence multiple times and it didn't help.
One example of the issues is shown in the link below:
drive.google.com/open
any suggestions?
thanks a lot,
Kevin
    Kevin,
    I've not seen this before. Perhaps you can add a marker rather than the the cursor instead? This is an obsolete version of the software, which is now beyond the final support date (the last hotfix was 3.5 years ago).
