  3. Advanced function with Virtuoso Cadence
  • Views 21086
zizo2012
zizo2012 over 11 years ago
I work on the characterization of an amplifier circuit in Cadence Virtuoso and I do not know how to perform some function in the calculator.Please can you help me and send me an advanced tutorial on the use of this software or help me by answering the following questions and I will be very grateful?
Q1: How to determine the parasitic impedance (R, C, L) of a circuit in Virtuoso and trace the signal of the real part and the imaginary part (in dB) versus frequency?
Q2: How to determine the value of the harmonic distortion of the output signal, and how to plot it versus the frequency?
Q3: How to identify and trace the change in equivalent noise brought back into function of frequency?
Q4: How to determine the power dissipated by the circuit?
Thank you.
    This is a bit more than "how to perform some function in the calculator". Mostly this is about knowing what analysis to run in the simulator.
    Some (short) answers given that these are potentially big subjects in themselves. Hopefully this will point you in the right direction though.
    1. Several ways you could do this. One is to use an sp (s-parameter) analysis, and another is to use ac analysis. There are functions to plot the s-parameter results, and there's also the real and imag functions in the calculator. Depends on what you're really trying to do here...
    2. You could use tran analysis, and then the thd function in the calculator. Or you could use the pss or hb analysis and directly get the resulting spectrum. Not sure that harmonic distortion versus frequency is quite what you want - it wasn't clear though.
    3. Perform a noise analysis? Depends what you mean by "equivalent noise".
    4. Measure the current through your supplies and then multiply it by the voltage across the circuit. Probably use rms function to give you the RMS power?
  • zizo2012
    hello,
    Thank you very much for your answers.
    I want to know, can you tell me for the form of input impedance (Rin // Cin) if I trace "Real (V / I)" I'll find 'Rin' and if I trace "Imag (I / V )" I will find '(Cin * 2p * f)'?
    and what is the equivalent function to plot the module of my impedance ?
    Can you give me more detail about how use these functions because I can not get access to Cadence Online Support?
    Best regards.
    ShawnLogan over 11 years ago
    Dear zizo2012,
    Yes. Your expressions will yield the equivalent real and imaginary input impedance expressed as a real and capacitive input. Your capacitance may be negative if the imaginary component is inductive. (I assume you meant "pi" and not "p".)
    You can plot these expressions using the real() and imag() functions directly from the calculator tool called up in ADE-L. Alternately, you can add the resulting calculator expressions as outputs in ADE-L.
    Shawn
  • zizo2012
    hello,
    I come to asking you how i can determine the power dissipated in a circuit in Virtuoso?
    my circuit is big and complicated so I can not calculate the current and voltage at each point.
    Under PSPICE I can read directly the power in the output file, but in Virtuoso I did not find that file or another method to determine this power.
    Dear zizo212,
    Is there a reason you cannot use a current probe in series with an ideal supply (or supplies) connected to the power node(s) of your circuit block? After the simulation completes, taking the average of the current through the probe and multiplying it by the respective supply voltage will provide the average power. The instantaneous power may also be determined. Perhaps I am misunderstanding your question - my apologies if I am!
    Shawn
