  3. simvision schematic cross probing
  • Views 15384
Ham En
Ham En over 11 years ago
Using cross selection we can very easily make the cross-probe of the nets.
using this option the net can be easily highlighted in the SimVision windows(waveform window, ...), but the problem is that the net selected in the waveform window is also highlighted in schematic editor.
Is there any solution to make this option unidirectional, so that only from schematic to waveform function.
    I don't think so - if I remember rightly, you need to turn on the cross selection in the Editor Options (might be Display Options - I can't check right now) in the schematic editor - and doing so enables the cross-selection in both directions.
