  3. RLC model parameters
  • Views 15101
SoonG
SoonG over 11 years ago
Is there way to generate the values of the R,L,and C from the layout routing structure information with the length, width, distance from subtract etc.
in the cadence spectre? I just want to use the RLC schematic unit model for the high speed(10 GHz clock) layout routing for the simulation.
Soon
  • Marc Heise
    Marc Heise over 11 years ago
    Hi Soon,
    the tool you are looking for is called QRC.  This will take a LVS-clean layout view and extract the parasitic devices. After the extraction you
    can refine (filter) the results and create a netlistable cellview which Spectre can simulate. You will need the runset files for the LVS and the
    extraction for your technology node and the software ( PVS/QRC).
    Kind regards,
    Marc
