  3. Failed to build VDB. Cannot submit DRC Run
  • Views 25038
V4vlsi
V4vlsi over 11 years ago
while doing simple DRC Run of an simple inverter Layout.  I am getting the following error.
Loading tech rule set file : /mnt/Newhdd/Cadence_tools/UMC180/RuleDecks/Assura/techRuleSets
Assura DRC: State saved "Last"
Compiling rules...
*Error* load: can't access file - "/Newhdd/PDKS/UMC180/RuleDecks/Assura/DRC/G-DF-LOGIC18-1.8V-3.3V-1P6M-Assura-drc-memory.rul"
Errors exist in the rules file '/mnt/Newhdd/Cadence_tools/UMC180/RuleDecks/Assura/./DRC/G-DF-MIXEDMODE_RFCMOS18-1.8V-3.3V-1P6M-MMC-Assura-drc-2.11-p1.rul'.
*WARNING* Failed to build VDB. Cannot submit DRC Run.
Assura DRC: State loaded "Last"
I am using Cadence Virtuoso version IC6.1.5.500.11. and DRC engine ASSURA 4.1_USR2HF2. Is there any compatibility issue thit the version of virtuoso and ASSURA.?
PLZ help. Thanks in advance.
    I'm not sure why you think it's a compatibility issue? The error message looks pretty clear to me - something is referencing a file, and it can't find that file. Since the file in question appears to be part of the rule decks, it suggests a problem with the installation of the rule decks, not the tool.
    Check to see if the path in question exists - maybe it is a permission problem? Then look at the other files to see where this is referenced - maybe there is a switch you need to set to avoid this. Also check whether it has been installed correctly. Finally, check with the providers of the rule decks...
  • kapiljainwal
    kapiljainwal over 10 years ago
    Dear Andrew,
    I  am also facing the same error.
    I am working on IC615. LVS is running fine but DRC is showing the error that "Failed to built VDB, Cannot submit the DRC run."
    One more this I found that while I am opening the  "Open Run" under "Assura" tab I can only see run name as LVS and not for DRC.
    I am not able to resolve the problem. Is it due to missing run name file for DRC or something else because LVS is running properly.
    If the problem is exactly the same (with the same preceding errors), then my guess is now as it was then, that you have a permission problem. However, you didn't show what all the errors were - only the final error (which is probably the consequence of an earlier error).
    It's hardly surprising that the run name for the DRC is missing from the Open Run, because the run didn't complete - Open Run only shows you completed runs.
  • kapiljainwal
    Dear Andrew,
    I got the solution. The rule file (G-DF-MIXEDMODE_RFCMOS18-1.8V-3.3V-1P6M-MMC-Assura-drc-2.9-p2.rul) contains the path of another rule file (G-DF-LOGIC18-1.8V-3.3V-1P6M-Assura-drc-memory.rul) which was located at different place then the mentioned path. I changed the path of later one and now DRC is working fine.
    Kapil Jainwal
