  3. How to creat a uniform distribution in source file for Monte...
  • Replies 8
  • Views 22132
How to creat a uniform distribution in source file for Monte-Carlo simulation?
UUinfini
UUinfini over 11 years ago
Hello all,
Does anyone know how to creat a uniform distribution in source file for Monte-Carlo simulation? As the gaussian distribution is:
vary seed dist=gauss std=1
And could you recommend a document which details this part of Cadence?
Thank you very much in advance.
    As part of my effort to encourage people to look in the documentation, either use "spectre -h montecarlo", or run "cdnshelp" from the MMSIM installation (e.g. `cds_root spectre`/tools/bin/cdnshelp). Search for the word "uniform" and then in the results, click on the link about Monte Carlo Analysis (rather than the Verilog-A language documentation that may be the first hit).
    This will tell you how to do it.
  • lartola
    lartola over 9 years ago
    I would use the function $rdist_uniform to generate random real number. But, Verilog-A language can bu use in Ocean Script ?
    Thank for your time
    Regards
    Laurent
  • UUinfini
    UUinfini over 9 years ago
    I don't think so.
  • lartola
    So how can I deal with that ?
    It's not clear what you're actually asking here. Are you asking if you can create a VerilogA view and then simulate that from OCEAN? If so, then the answer is yes - you just either use a config (with the hierarchy editor) as the design and pick the VerilogA view to use for the cell in question (you can also control it via the view list - corresponds to Setup->Environment in ADE - if you're not using a config).
    If you're asking if you can use VerilogA syntax in the OCEAN script itself, then the answer is no.
    If you want to generate a random number in OCEAN (which is just SKILL), then  you can just use the random() function (type "help random" in the CIW to find out a short summary of how it works).
  • lartola
    Thanks for this clarification Andrew. I have used it in Ocean ($rdist_normal); however, the random generation in SKILL does not follow a gaussian law. I didn't find in the help file a way to generate number following a gaussian law with SKILL syntax.
    Thanks in advance for your time
    Laurent
    Laurent,
    You were asking about $rdist_uniform so I assumed you wanted a uniform distribution, not a gaussian (normal) distribution. You can use this SKILL code below if you want to generate random numbers with a gaussian distribution:
    /* abRandomNormal.il
    Author     A.D.Beckett
    Language   SKILL
    Date
    Modified
    By
    Uses Box-Muller method to produce random numbers with
    a normal distribution (mean 0, std dev 1).
    Call abRandomNormal() multiple times to get such a sequence.
    SCCS Info: @(#) abRandomNormal.il 11/30/12.14:22:28 1.1
    ; Store math constants (such as PI) as properties on this symbol
    (defMathConstants 'abRandomNormal)
    *                       (abRandomNormal)                       *
    *  Return a random number with normal distribution using the   *
    *                      Box-Muller method                       *
    (defun abRandomNormal ()
      (let ((max (rightshift -1 1)) U V)
        (setq U (quotient (float (random max)) max))
        (setq V (quotient (float (random max)) max))
        ; could generate two independent numbers
        ; the other would use cos instead of sin
        (times (sqrt (times -2 (log U)))
               (cos (times 2 (getqq abRandomNormal PI) V)))
    *             (abTestRandomNormal numPoints bins)              *
    *   Function for testing - uses ViVA's plotting functions to   *
    *  produce a histogram and also compute the mean and std dev   *
    *      to ensure that with enough points it looks normal       *
    *               (e.g numPoints 100000, bins 100)               *
    (defun abTestRandomNormal (numPoints bins)
      (let (x y wave)
        (setq x (drCreateVec 'intlong numPoints))
        (setq y (drCreateVec 'double numPoints))
        (for i 0 numPoints
             (drAddElem x i)
             (drAddElem y (abRandomNormal))
        (setq wave (drCreateWaveform x y))
        (awvPlotWaveform (newWindow) (list (histo wave bins nil nil)))
        (printf "Mean=%g\nStd Dev=%g\n" (average wave) (stddev wave))
  • lartola
    Thanks I will try your code !
    regards
    laurent
