  3. How to run LVS without v2lvs
  • Views 18574
Hypnus
Hypnus over 11 years ago
I am designing a mixed signal circuit, while for the digital part I could run LVS directly using .v file from encounter with the standard cell cdl file, but for a mixed signal circuit, and I don't have v2lvs from calibre, we have only assura to run everything, how could I run the LVS......please give me some tips, please...
Thank you really much!
Bison
    Bison,
    Assura LVS can read Verilog and CDL directly. There is no need for a utility such as v2lvs. The Assura LVS forms in Virtuoso provide the ability to specify a mix of netlists, and the same can be done from the command line.
    I don't have access to my work laptop at the moment so can't easily check how to do this, but it should be covered in the Assura documentation.
    Kind Regards,
  • Hypnus
    Thank you so much for your reply, I understand that assura could read verilog and cdl directly, that's how I run LVS for the digital part, but digital part only.
    Now I want to add some analog blocks to create the whole circuit, that means a whole netlist or cdl or something that I can take as the input of assura's lvs that includes both the information of digital and analog parts is needed.
    The digital part is a .v file from encounter, I can import it into cadence but could only as a functional block, nothing in it, or I could use the .v file as one of the input of Assura's LVS, could you tell me how can I generate the file that includes all the information? Or how could I set the LVS while adding inputs separately? Could you give me some guidance when you have time? I am also going to try to find some solutions in Assura's document.
    Thanks again,
    Bison
  • Hypnus
    Hi Andrew, Also could you tell me which assura document should I read?
    OK, I did some experiments and read the documentation for you...
    In the "rsf" (run-specific file), you need to use this kind of construct:
    avCompareRules(
    schematic(
    netlist( cdl "/export/home/myuser/support/playGPDK/file1.cdl" )
    netlist( verilog "/export/home/myuser/support/playGPDK/file2.v" )
    bindingFile("/export/home/myuser/kits/gpdk090_v4.6/assura/bind.rul")
    If you run $ASSURAHOME/tools/bin/cdnshelp and then search for avCompareRules you'll find relevant references. In particular there's a sectionin the Assura Physical Verification Command Reference which details the syntax of the options for the schematic block including the netlist statement.
    There is also a general section in the "Assura Physical Verification User Guide" on "Comparing Layout and Schematic Netlists", and a subsection in that called "Directing the LVS Run with Compare Rules", which explains it pretty well. Given that there are not huge numbers of Assura manuals, finding the information is quite straightforward.
    I also generated the example above using the UI for Assura LVS within Virtuoso.
