  3. Monte Carlo Mismatch
  • Views 18825
syafiq
syafiq over 11 years ago
I am a little bit confuse about mismatch variations in monte carlo. After I select "Monte Carlo Sampling" and then when I click simulation options, one window will pop-up which allow you to setup your monte carlo.
I wanted to introduce process and mismatch variations for my monte carlo analysis. So I choose All to select both process statistical variations and mismatch variations.
Is it true if I select All, then mismatch variations are applied to all sub-circuit instances in the design?
OR do I need to include all sub-circuit instances by setting up in the "Specify Instances/Devices" so that all sub-circuit instances are subject to mismatch variations?
Syafiq
  • Tom Volden
    Tom Volden over 11 years ago
    Hi Syafiq,
    If you select All for Statistical Variation both process and mismatch variation will be applied to all devices by default.  "Specify Instances/Devices" is only needed if you want to limit the statistical variation to a subset of the devices or to synchronize the application of variation across multiple tests.
    TOM
  • syafiq
    Hello Tom, Thanks for your clarifications.
  • Ziyad Almohaimeed
    Ziyad Almohaimeed over 11 years ago
    Hi Tom :
    is it normal to have the standard deviation equal to zero or in scale of femto while the mean in scale of micro when i apply Monte carlo mismatch variation? or there is something wrong with the statistcal script?
    The same (follow-on) question was asked in another thread, so some answers to the last append are here:
    Please do not post in multiple threads (and ideally not on the end of an old thread for somebody else).
