  3. How to get the total area/length of a path with marknet...
  • Views 3651
How to get the total area/length of a path with marknet ?
gnamde
gnamde over 11 years ago
I am interested to get the effective area or length of the paths traced or highlighted by marknet function. If the path is highlighted by marknet option at the fullchip level, I need to get the complete length hierarchically, avoiding manual calculations.How can I get that?
Further if I can get area/length of atleast the individual traces of different Metal from point to point connecting through the hierarchically would be great.
My requirement is to match the length/ parasitics of multiple nets.
    If you have access to the EAD tool (Virtuoso Layout Suite Electrically Aware Design) then this can do a point to point measurement of resistance and capacitance.
    If you don't have that, then you could use Mark Net, and then the command to save the mark net info into a new cellView. Then using the code in Solution 11328674 you could measure the area of the resulting shapes. There's another solution pointed to from that one which gives an alternative approach (the mark net shapes are already flat, so much of what this does isn't really necessary).
  • gnamde
    Thanks Andrew, I could able to do that via MarkNet.
  • gnamde
    I checked we do have license for EAD . How can I use it ? (Q1) > I could only able to use constraint manager to pass the constraints as a Max Cap/res to a net in schematic., but don't know how to cross-check that the constraint in layout is met !. Also this is a kind of electrical aware design while doing a layout. (Q2) >At present I am having an existing fullchip layout how can I use EAD tool for measuring point to point resistance ? ....-Thanks!
    Giving a full EAD tutorial here is not a viable option. Please contact customer support - or look at the Rapid Adoption Kits (search on that page for EAD).
