  3. Problems in running BSIMCMG108.0.0 FinFET Models in Cadence...
  • Views 15541
Problems in running BSIMCMG108.0.0 FinFET Models in Cadence Virtuoso
Manju bp
Manju bp over 11 years ago
 I am new to FinFETs. I need to design circuit using 32nm FinFET. I have downloaded BSIMCMG108.0.0 Files and used in Cadence Virtuoso version IC6.1.5-64b.500.11.  While compiling I am stuck with the following errors.
Error found by spectre during AHDL read-in.
ERROR (VACOMP-2065): "/home/bhuvana/cadence_DB/scratch/varal/cadence/cadence_ms_labs_613/BSIMCMG108/PFin_fet/veriloga/bsimcmg_body.include", near line 4564: Encountered ddx operator in a conditional (if-else) statement. ddx operator cannot appear in a conditional (if-else) statement. Correct the problem and try again.
ERROR (VACOMP-1816): Exiting AHDL compilation.
ERROR (SFE-91): Error when elaborating the instance bsimcmg. Simulation should be terminated.
Can anyone please help me solving this problem?
    Please use the community search - this has been answered several times before (or rather an alternative to using the Verilog-A)
  • Manju bp
    Thank you for your reply. I have followed the links as you mentioned, but still I found the same errros.
    I have followed these steps. Whether the steps are correct?
    I have saved the BSIMCMG108.0.0 in the requied path.
    Created a new cell with Verilog A.
    It creates a black box with s,d,g,e pins.
    In tools , CDF->EDIT-> edited parameters-> Save.
    In ADE L , I attached model files modelcard.nmos and modelcard.pmos
    Then I compiled it again. I found the same errors again.
