  3. Problem in QRC Extraction due to inconsistent models
  • Views 15241
Casp
Casp over 11 years ago
  I am using IC6.1.5 and running QRC Extraction. I am getting errors like
"*ERROR* Terminal B on device (dmos) in the extraction rules is not present on the dfII cellview (CMOS14 dmos symbol)"
This is because of inconsistent models in pdk and extract rule file and QRC Extraction Terminates. But in my schematic/layout I am not using any device which has inconsistent model.  Can you please tell me that is there any switch which I can turn on to just look at the devices which I have only in schematic/layout?
Regards
    This might be fixed in IC616 (also ensure you're using a recent EXT release for QRC, e.g. EXT142). I'm assuming you have "Enable CellView check" turned off on the Setup tab of the QRC form?
    Can you check if it still occurs using the latest version of IC and EXT? If so, please contact customer support as this could well be a bug - we'd need to see the data though.
  • Casp
    Thanks Andrew. I updated the cadence to IC6.1.6 and it is working fine.
  • DeepAG
    DeepAG over 9 years ago
    Sir,
    > I am building an LC oscillator and have done its QRC, But when I do ADE
    > transient analysis without parasitics, o/p is coming properly but in case
    > of with parasitics the o/p is straight line,  here its showing how many
    > parasitics resistors and capacitors are there.what do i do now?
    > Please help.I will be grateful to you
