  3. How to extract MPP cut shapes
  • Views 15001
Ferdz
Ferdz over 11 years ago
I have a MPP which is constructed like a co-axial shield.
My problem is, the connectivity of the Subpart->Subrectangle are not extracted.
I heard that in cadence 6.1.6.500.8 / 9 /10 there is an envar to fix this
envSetVal("layoutXL" "_extractIgnoreMPPCutShapes" ‘boolean nil)
But I am using cadence 6.1.6.500.7, the envar mentioned above is not yet registered to this cadence version.
Anyone who has a solution?
Thanks in advance,
Ferdinand
    Wouldn't the simplest solution be just to move to a later hotfix? (I don't know of a workaround without spending time looking into this in more detail, which I don't have at the moment).
  • skillUser
    skillUser over 11 years ago
    Hi Ferdinand,
    I don't have time to test this, but you have access to all of the constituent parts of an MPP, I think from the top-level ROD object you can look over the subShapes and then investigate or set the connectivity (via the 'net' attribute).  If you have the master selected, try something like this:
    rodId = rogGetObject(car(geGetSelectedSet()))
    ;; look at the following
    rodId~>subShapes~>net
    ;; ... and if they were all nil, try this
    rodId~>subShapes~>net = rodId~>dbId~>net
    Hopefully this will work as a short-term workaround until you can move to a new release?
    Lawrence.
  • Ferdz
    Hi Andrew and Lawrence,
    Thanks for your response.
    Unfortunately I have no freedom to deviate from our project environment so I can't use later cadence version,
    and indeed I am left with a workaround to assign nets manually(or  by skill).
    regards,
    Ferdinand
