  3. QRC Extraction - Assura
  • Views 2449
Paolo Minotti
Paolo Minotti over 11 years ago
Hi all,
I am trying to extract the parasitics of my layout.
I get an error message I cannot understand the source.
Here's the log:
Cadence Extraction QRC - 64-bit Parasitic Extractor - Version 9.1.3-p003
Thu Jun 24 10:49:17 PDT 2010
Copyright 2010 Cadence Design Systems, Inc.
INFO (EXTQRCXOPT-249) : For Assura inputs, if the "output_setup -directory_name" option was not
specified, it is automatically set to the input directory.
INFO (LBRCXU-108): Starting
/usr/local/cadence//ASSURA_4.1OA-614/tools/assura/bin/rcxToDfII /media/storage-3/AMSWorkArea/ASSURA_LVS/0_drive_PADS/0_drive_PADS/__qrc.rcx_cmd -t -f
/media/storage-3/AMSWorkArea/ASSURA_LVS/0_drive_PADS/0_drive_PADS/extview.tmp -w /media/storage-3/AMSWorkArea/ASSURA_LVS/0_drive_PADS/0_drive_PADS -cdslib
/media/storage-3/AMSWorkArea/cds.lib
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.07s.
@(#)$CDS: rcxToDfII_64 version av4.1:Production:dfII6.1.4-64b:IC6.1.4-64b.485 07/07/2010 03:51 (sjfql241) $
sub-version 4.1_USR1_HF10, integ signature 2010-07-07-0307
run on pcsandlab3-2.elet.polimi.it from /usr/local/cadence/ASSURA_4.1OA-614/tools.lnx86/assura/bin/64bit/rcxToDfII on Fri Jul 24 15:41:43 2015
Loading tech rule set file : /media/storage-3/AMSC35B4C3/assura/c35b4/c35b4c3/techRuleSets
Loading all available p-cell functions
AMS_DB set to cds
No mx check
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (esdpd18 auLvs) from lib (ESDLIB) in 'r' mode because cellview does not exist, or
cellview type is not recognized by dbOpenCellViewByType.
*WARNING* No library model for device "esdpd18 auLvs ESDLIB".
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (esdpd26 auLvs) from lib (ESDLIB) in 'r' mode because cellview does not exist, or
*WARNING* No library model for device "esdpd26 auLvs ESDLIB".
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (esdpd30 auLvs) from lib (ESDLIB) in 'r' mode because cellview does not exist, or
*WARNING* No library model for device "esdpd30 auLvs ESDLIB".
*WARNING* (DB-270210): dbOpenCellViewByType: library 'IOLIB_4M' does not exist
*WARNING* No library model for device "probepad auLvs IOLIB_4M".
*WARNING* (DB-270210): dbOpenCellViewByType: library 'PRIMLIBRF' does not exist
*WARNING* No library model for device "nmosrf auLvs PRIMLIBRF".
*WARNING* No library model for device "pmosrf auLvs PRIMLIBRF".
*WARNING* No library model for device "cpolyrf auLvs PRIMLIBRF".
*WARNING* No library model for device "rpoly2rf auLvs PRIMLIBRF".
*WARNING* No library model for device "rpolyhrf auLvs PRIMLIBRF".
*WARNING* (DB-270210): dbOpenCellViewByType: library 'SPIRALS_4M' does not exist
*WARNING* No library model for device "SP014S300D auLvs SPIRALS_4M".
*WARNING* No library model for device "SP020S180D auLvs SPIRALS_4M".
*WARNING* No library model for device "SP026S200D auLvs SPIRALS_4M".
*WARNING* No library model for device "SP037S180D auLvs SPIRALS_4M".
*WARNING* No library model for device "SP047S180D auLvs SPIRALS_4M".
*WARNING* No library model for device "SP050S155D auLvs SPIRALS_4M".
*WARNING* No library model for device "SP090S155D auLvs SPIRALS_4M".
INFO (LBRCXU-114): Finished /usr/local/cadence//ASSURA_4.1OA-614/tools/assura/bin/rcxToDfII
/usr/local/cadence//ASSURA_4.1OA-614/tools/assura/bin/avRCXxref /media/storage-3/AMSWorkArea/ASSURA_LVS/0_drive_PADS/0_drive_PADS/__qrc.rcx_cmd -useRunName
@(#)$CDS: avRCXxref_64 version av4.1:Production:dfII6.1.4-64b:IC6.1.4-64b.485 07/07/2010 03:49 (sjfql241) $
run on pcsandlab3-2.elet.polimi.it at Fri Jul 24 15:41:43 2015
Reading rsf
INFO (LBRCXU-114): Finished /usr/local/cadence//ASSURA_4.1OA-614/tools/assura/bin/avRCXxref
INFO (LBRCXM-642): Constructing the RCX run script
INFO (LBMISC-215205):
*** Cadence Extraction QRC Techgen -trans VERSION 9.1 Linux 32 bit - (Mon Jun 21
09:44:05 PDT 2010)  ***
INFO (CAPGEN-41199):
Techgen -trans results will be written to directory: /media/storage-3/AMSWorkArea/ASSURA_LVS/0_drive_PADS/0_drive_PADS
ERROR (LBMISC-215479): at "Techgen -trans": Connect layer 'net_nwell' from lvsfile is declared as stamped layer in p2lvsfile. Please check the p2lvsfile.
INFO (RCXSPIC-27150): The following forked command failed. Contact Cadence Customer Support for assistance.
/usr/local/cadence/EXT_9.1/tools.lnx86/extraction/bin/64bit//capgen -techdir /media/storage-3/AMSC35B4C3/assura/c35b4/c35b4/RCX-typical -lvs /media/storage-
3/AMSWorkArea/ASSURA_LVS/0_drive_PADS/0_drive_PADS.xcn -p2lvs /media/storage-3/AMSC35B4C3/assura/c35b4/c35b4/RCX-typical/qrcTechFile -sd -sw3d -
auto_reorder_off -length_units meters -cap_unit 1.0 -selected_paths_proper -p poly1,capgen_gate,pdiff -no_cap_correction -cap_ground_layer net_psub -dsub
net_nwell,net_psub -lexclude poly2,poly1 -blocking cblock_met2cap_met2,met2cap,met2 -blocking cblock_met1_fox,met1,poly2,poly1,pdiff,fox -blocking
cblock_poly2_poly1,poly2,poly1 -res_blocking rblock_poly1,net_poly1 -res_blocking rblock_poly2,net_poly2 -res_blocking rblock_met1,net_met1 -res_blocking
rblock_met2,net_met2 -res_blocking rblock_met3,net_met3 -res_blocking rblock_met4,net_met4 /media/storage-3/AMSWorkArea/ASSURA_LVS/0_drive_PADS/0_drive_PADS
Forking:  /usr/local/cadence/EXT_9.1/tools.lnx86/extraction/bin/64bit//capgen -techdir /media/storage-3/AMSC35B4C3/assura/c35b4/c35b4/RCX-typical -lvs
/media/storage-3/AMSWorkArea/ASSURA_LVS/0_drive_PADS/0_drive_PADS.xcn -p2lvs /media/storage-3/AMSC35B4C3/assura/c35b4/c35b4/RCX-typical/qrcTechFile -sd -sw3d
-auto_reorder_off -length_units meters -cap_unit 1.0 -selected_paths_proper -p poly1,capgen_gate,pdiff -no_cap_correction -cap_ground_layer net_psub -dsub
ERROR (LBRCXM-644): Bad return status from RCX script generator. 0x100
INFO (LBRCXM-709): *****  QRC terminated abnormally  *****
Any idea/suggestion?
Thank you,
Paolo
  • Quek
    Quek over 10 years ago
    Hi Paolo
    The above error usually means that there is a problem with the layer mapping in the QRC package. It would be good if you can check if there are any updates for the package.  Alternatively, you can try to resolve the problem as follows:
    a. Check "net_nwell" line in layerSetupFile (or layer_setup) in QRC technology directory
    b. If there are keywords such as "stamp=1/2", remove them
    c. Check RCXspiceINIT file for the previous compilation options. Re-compile the package with Techgen using the same options
    By the way, your current QRC is ver9.1.3. It is really quite out-dated. If it is possible, please kindly update to ver15.11.
    Best regards
    Quek
