  3. Regarding Cadence Virtuoso gpdk45nm technology spectre model...
  • Views 17631
Regarding Cadence Virtuoso gpdk45nm technology spectre model file.
PS90
PS90 over 11 years ago
I am designing ampilfier circuit in cadence virtuoso using gpdk45nm technology spectre model file. I am finding difficulty in figuring out the exact mobility of either of pMOS or nMOS transistors. For example, in one of the geometrical model in file the mobility of pMOS is given as u0=0.02305+du0_p and for nMOS u0=0.01528+du0_n. In typical-typical standard process (given in file) the value for du0_p and du0_p is 0, which means that mobility of pMOS is greater than nMOS which is not possible. All the initial values of pMOS is greater than nMOS in all the geometrical models given in file. Mobility of holes can never be greater than electrons. So, how these mobility values are decided or there is another method to estimate the mobility values of nMOS and pMOS. Please reply soon.
  • PirateKing2008
    PirateKing2008 over 11 years ago
    Hi Pushkar, Do you need to know u0? Would K' do? You can simulate K' by simulation squareRoot(iD) Vs Vgs for a long device so lamda << 1. Then measure the gradient m on the straight part of the graph then m = squareRoot (K'W/2L) then you can work out K' and K' = uoCox but surely K' is good enough. You can also extrapolate the line so where it intersects with X-axis is VT0 as long a VBS = 0 so VT = VT0.
  • PS90
    Thanks for the reply. But, i was asking about the mobility values given in the cadence virtuoso gpdk45nm technology file. Here in this file, the mobility of holes seems to be greater than mobility of electrons. Is this possible? Or there is some another method to look for/calculate mobility values in the gpdk45nm technology file. For designing circuits, mobility values are an important factor for deciding the aspect ratios and we find these values generally in technology files. We generally know hole mobility is less than electron mobility because of which for same current value pMOS aspect ratio is greater than nMOS aspect ratio.
    It does seem a bit odd, I agree. However, this is a completely fictional process, and it may have just been a mistake when the models were "fitted".
