  3. Error: Failed to elaborate("Library Name" "Cell Name" "config...
  • Replies 12
  • Views 8396
Error: Failed to elaborate("Library Name" "Cell Name" "config")
Casp
Casp over 11 years ago
  I am using IC6.1.6 and trying to simulate extracted view using Hierarchy Editor. I am getting two errors.
   1.  Failed to load dynamic library libadsptolemy_vpi
   2.  Failed to elaborate ("Library Name" "Cell_name" "config")
Can you please tell me the possible reasons for this problem? I also have veriloga switch in the config view.
    The first error is related to a non-Cadence tool (from Keysight - formerly Agilent) and you've not given enough details for the second. I assume this is an AMS simulation? Which simulator are you using? Which version of the simulator?
  • Casp
    Casp over 10 years ago
    Yes it is AMS simulation and I am using spectre 12.1.1.164.isr15.
    If it's AMS, then you're not running spectre. So the INCISIVE version is needed (this is in the output log).
    Please provide the log file with the details of the error message - the question is too vague at the moment to be able to stand any chance of resolving it.
  • VictorWu
    VictorWu over 5 years ago
    Did you solve  the problem?
    Andrew Beckett over 5 years ago in reply to VictorWu
    Victor,
    Which problem are you talking about? The original description was rather vague, so please provide details of what your actual issue is. Even the "elaboration" question was probably related to using an old AMS flow (cellview based netlisting) at a guess (since I don't know really what the issue was).
  • VictorWu
    VictorWu over 5 years ago in reply to Andrew Beckett
    Andrew,
    It happened when I did postlayout simulation. The format of the output of PEX is Hspice, and I set the cell view to SPICE source file in the config. The version of  cadence is IC615 and the simulator is AMS, the NETLIST AND RUN MOD is Cellview-based netlister with ncvlog, ncelab, ncsim.
    That just looks as if you haven't provided the spectre models for the transistors via Setup->Model Libraries in ADE.
    By the way, it's not really a good idea to be using such an old version of the tools.
  • VictorWu
    What spectre models should I provid and which way of postlayout simulation would you recommand. I would be very appreciate it.
    Presumably if you simulate anything with the transistors in, you'd need to provide spectre models for the transistors themselves. It's the same models you're using to do that - the models provided with your PDK (design kit) from the foundry.
    I'm not sure what you're asking when you ask "which way of post layout simulation would you recommend".
  • VictorWu
    I can perform the pre-simulation with the model shown in the picture. I don't know why it is not working for the postlayout simulation. For "which way of post layout simulation would you recommend", I mean what tools should I use to perform the postlayout simulation, since that you told me "it's not really a good idea to be using such an old version of the tools."
