  3. Adding "FILE NAME" as a parameter in verilog-A module
  • Views 3872
RFStuff
RFStuff over 11 years ago
Dear All,
I have written a Verilog-A code which writes simulation data into the file (file_name.txt).
I want to use the file name as a variable(parameter) so that I can change the file name for different instances of the module.
Could anybody please tell how it can be done ?
`include "constants.vams"
`include "disciplines.vams"
module FILE_WRITE( VIN,clk_edge_rise);
 input VIN;
 electrical VIN,clk_edge_rise;
 integer fp1;
integer count ;
 analog begin
  @(initial_step) begin
      count=0;
     fp1=$fopen("/home/MAT_WORK_CAD/MODULATOR/file_name.txt","w");
   end
   @(cross(V(clk_edge_rise) - Vth, dir, ttol, vtol)) begin
     count=count+1;
     $fwrite(fp1, "%d , %.15E\n", count,V(VIN) );
    end
    @(final_step) begin
      $fclose(fp1);
    end
  end
endmodule
Kind Regards,
  • theopaone
    theopaone over 11 years ago
    I don't know the language this is written in but your file name in the $fopen call is a string and not a variable. You have to build the file name from the directory path and the variable file_name. In SKILL, this is done with
    sprintf( nil "/home/MAT_WORK_CAD/MODULATOR/%s.txt" file_name)
    You will have to translate this into something Verilog understands.
    Ted
