  3. Analog Layout Design
  • Subscribers 136
  • Views 19398
PS90
PS90 over 10 years ago
I have made an analog circuit in mosfet weak inversion region. The aspect ratio of many mosfets are like (W/L)=(0.4u/15u). During DRC run(in layout), the virtuoso gives errors "13A1: P+SD to NW tap spacing must be <=10um" and "13A3: N+SD to Psub tap spacing must be 10<=um", for almost all the  mosfets. Please help for diagnosing this error.
  • theopaone
    theopaone over 10 years ago
    Where are your nwell taps and p substrate taps? That is what the errors are pointing out. Put in more taps within 10um of the gates. It would help if you could post a picture.
  • PS90
    Thank you very much for your valuable reply. I have solved all the errors.
  • HolmesS
    HolmesS over 5 years ago
    Can you please tell me how did you solve the errors? attaching my inverter design too.
