  3. ADEXL worst corner summary after simulations are done.
  • Views 15660
vamshiky
vamshiky over 10 years ago
Is there any way to get a simple summary for some important measurements for min/max and the corresponding PVT corner+design variable.
this would be quite handy for documentation of the results.
Vamshi
    Vamshi,
    Isn't the "Summary" view sufficient? (where you have the combo box field to select Detail/Detail - Transpose/Summary etc)
    If not, what are you looking for that's not there? Please be very clear.
  • vamshiky
    Andrew,
    The summary view only shows the outputs and min/,max etc summary. (infact its present in Detail view itself)
    What I am interested is the PVT corner where that min/max has occurred,  especially when we have some hundreds of PVTs + load +reference design parameters swept. It takes a while to figure out (scroll through all the list of results)  in which combination of PVT has the min/max occurred.
    Vamshi
    Vamshi,
    You should contact customer support - there is an enhancement CCR asking for this (1151615) - so you should request a duplicate CCR to increase the chances of this being implemented sooner rather than later.
    Potentially the information could be found using SKILL code (using axlReadHistoryResDB) but I don't have the bandwidth to write an example at the moment.
  • vamshiky
    Thanks  Andrew.
