  3. Sublibraries in Cadence VIrtuoso
  • Views 17043
jsaenznoval
jsaenznoval over 10 years ago
Hi everyone,
I just want to create a library inside another one using library manager. I can't use categories because my cells share names with cells from other libraries.
Thanks!
    There is no such thing as a "sublibrary" or a library inside another one.
    You can however get the library manager to display multiple libraries as a "combined" library. For more details look in Chapter 2 of the Library Manager User Guide (at the end of the chapter). You can find this in cdnshelp, or looking at <ICinstDir>/doc/libManager/libManager.pdf
    Maybe that's what you want?
  • theopaone
    theopaone over 10 years ago
    This is not supported in OpenAccess, the underlying database for Virtuoso. The categories are used to organize the cells within a single library so you can have shared named cells in multiple libraries, each library would have its own set of categories. When you place an instance, the instance header specifies the library, cell and view for the master so there is no conflict.
    You can create multiple libraries in the same directory and use the ASSIGN statement in the cds.lib file to make them appear as a single library in the library manager.
    Ted
