  3. Warnings during generation of layout from source
  • Subscribers 133
  • Views 17214
Preethi P
Preethi P over 10 years ago
I am designing a readout circuit using AMS hitkit v4.10, h35b4 technology. I am new to layouts.
I was generating layout all from source when I noticed the following warnings:
INFO (LX-1063): Building the layout generation form...
*WARNING* (LX-2003): Cannot create instance terminal on layout instance '|MP0' because the instance master 'PRIMLIB/pmos4/layout' does not have a corresponding terminal 'B'.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance '|MP1' because the instance master 'PRIMLIB/pmos4/layout' does not have a corresponding terminal 'B'.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance '|MP2' because the instance master 'PRIMLIB/pmos4/layout' does not have a corresponding terminal 'B'.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance '|MP5' because the instance master 'PRIMLIB/pmos4/layout' does not have a corresponding terminal 'B'.
*WARNING* (LX-2006): There were errors or warnings during layout generation.
INFO (LX-1030): Run Connectivity - Check - Against Source for more details.
INFO (LCE-1006): Cellview 'PRIMLIB/nmos4/layout' is extracted using technology library 'TECH_H35B4' from the top level cellview and not its attached technology library 'TECH_H35B3'.
INFO (LCE-1006): Cellview 'PRIMLIB/nmosi120m/layout' is extracted using technology library 'TECH_H35B4' from the top level cellview and not its attached technology library 'TECH_H35B3'.
INFO (LCE-1006): Cellview 'PRIMLIB/pmos4/layout' is extracted using technology library 'TECH_H35B4' from the top level cellview and not its attached technology library 'TECH_H35B3'.
INFO (LCE-1006): Cellview 'PRIMLIB/cpoly/layout' is extracted using technology library 'TECH_H35B4' from the top level cellview and not its attached technology library 'TECH_H35B3'.
I did read a few other posts similar to this but could not really figure out a way that could remove these warnings (I tried viewing the cds.lib, but I was not quite sure what I would need to add or modify)
Any help will be appreciated.
Thanks!
  • Preethi P
    Is it because I connected the bulk terminal manually in the schematic? (Can I ignore this warning?)
    I'm not familiar with the PDK in question, but this usually just means that the PCell for the component doesn't have a bulk terminal. That's not unusual for many PDKs, as they don't necessarily track the connectivity of the bulk. It's possible to put properties on the device in the PDK (usually in the CDF) to tell it to not generate or not check particular terminals which would suppress this warning, but it doesn't look as if AMS have done that in this case; you might want to feed that back to them.
    If there's no bulk terminal on the PCell, you can safely ignore this warning. However, be aware that VLS XL will then not be trying to (or be able to) check the connectivity of your bulk connections to the devices, since there's no connectivity for it in the  layout.
    Hope that helps!
    Kind Regards,
  • Preethi P
    Thanks. Will keep what you said in mind.
    Best,
    Preethi
