  3. on MMSIM141 under IC6.16 simulation setup problem
  • Views 14720
Ruixin
Ruixin over 10 years ago
Hi, Andrew,
I am trying to switch MMSIM111 to MMSIM141 under cadence 6.16.500.4.
My oa version is oa_v22.43.028. MMSIM141 version is 14.10.826.
It works fine by using MMSIM111, however, when I am trying to use MMSIM141, it reports error ADE-3036.
I type "spectre -W", it shows "sub-version 5.10.41_USR6.081308". Is it the correct version for MMSIM141?
Since I typed "spectre -W" for MMSIM111, it showed "sub-version 11.1.0.404.isr9", it is totally different from MMSIM141.
I am not quite sure what is going on in the IC simulation setup. Could someone help me figure out this problem?
Thank you!
Ruixin
  • Tom Volden
    Tom Volden over 10 years ago
    Hi Ruixin,
    Check your path.  You are picking up an ancient version of spectre from an IC 5.1.41 installation.
    TOM
