  3. Embedding or popping out the Palette window from the layout...
  • Views 17726
Embedding or popping out the Palette window from the layout editor...
deklein
deklein over 10 years ago
After getting used to having the Palette embedded in the layout window unlike the LSW of old, I recently started a 6.1.6 project where the Palette window is independent of the layout window. This is driving me nuts because it is always buried and with the advent of wide screen monitors, I much prefer to have it as part of the layout window.
I suspect this is my CAD group playing tricks on me again, but I cannot find instructions on how to embed the Palette back into the layout window. Clicking Window -> Assistants has no "Palette" option to make this happen. Checking for environment variables with the keyword PALETTE in them only turns up CDS_PALETTE_TYPE=SingleWindow.
So... What am I overlooking?
David
  • Marc Heise
    Marc Heise over 10 years ago
    Hi David,
    that environment variable is the reason behind the behaviour of the palette. "SingleWindow"  will give you a LSW like Palette (like in the old IC5.1.41 version). Non dockable, stays up even if the layout closes, shared with all open layout windows.
    What you probably looking for is setting that variable to:  "SingleAssistant"or "MultiAssistant".
     Set it before you start the virtuoso session, it wont have any effect on a running session.
    Marc
  • deklein
    Thanks. That did the trick and sure enough, I found where the CAD group slipped  the setting in. Evidently they have some folks who like the old LSW style window.
    Cheers,
    David
