  3. ADE XL: Limiting the max number of jobs in Local simulation...
  • Views 16968
ADE XL: Limiting the max number of jobs in Local simulation mode?
kentauta
kentauta over 10 years ago
Hello.
Is there a way to set a hard limit to the max number of parallel jobs in local simulation mode in ADE XL?
I have had situations where I enter a large number (say 50) in "Max. Jobs"  in Job Policy Setup and forget to change the Distribution Method from Local to LBS.  If I launch simulations with this, my local workstation locks up as all of the memory and CPU resources are taken up and the only solution is hard resetting the computer.
Alternatively, it would be nice if I can set different job policies to testbench debug (single run) and batch simulations.
  • Tom Volden
    Tom Volden over 10 years ago
    You can do this by registering a preRun trigger to check the value of maxjobs and the distribution method.  Something like:
    (define (RunStopper sessionName sdbHandle modeName testName)
      (when ((axlGetAttachedJobPolicy)->distributionmethod == "Local" && evalstring((axlGetAttachedJobPolicy)->maxjobs) > 5)
        (printf "Local distribution method used with maxjobs>5; terminating simulation\n")
        (envSetVal "adexl.simulation" "haltCurrentRunAfterPreRunTrigger" 'boolean t))
    (define (connect_handlers session_name)
    (axlSessionConnect session_name "preRun" 'RunStopper))
    (axlSessionRegisterCreationCallback 'connect_handlers)
  • kentauta
    Thanks, Tom! That works perfectly.
