  3. Import logo to Virtuoso schematic Editor
  • Views 21363
Richardv
Richardv over 10 years ago
Hi all,
Is it possible to import a picture (logo) to  Virtuoso schematic Editor ?
Richard
    Andrew Beckett over 10 years ago +1
    First of all you need to ensure you have an "xpm" (X PixMap) file with a small number of colours in it - you really don't want to try to import some high-colour file because you'll be there forever mapping…
    Richard,
    See this thread. It might help?
  • Richardv
    I'm not an expert in SKILL programming .
    Can you explain how you use your program ?
    Regards
    First of all you need to ensure you have an "xpm" (X PixMap) file with a small number of colours in it - you really don't want to try to import some high-colour file because you'll be there forever mapping the colours! So use an image processing tool (such as gimp) to manipulate the colours in your original logo and ensure it's saved as an xpm file.
    Then take the code in the post I referred to and save it in a  file called "abXpmToLayout.ils" (make sure it has a .ils suffix, although from looking at my code, it doesn't appear to be essential to have a .ils suffix). In the CIW, type:
    load("abXpmToLayout.ils")
    and then open the symbol that you want to add the logo in, and run:
    abXpmToLayout()
    You can then browse to your xpm file, map the colours on the form, and then place the shapes from the logo in your symbol.
  • Pedro Cardoso
    Pedro Cardoso over 5 years ago in reply to Andrew Beckett
    I know this is quite an old post, but I have a doubt with the way your script works.
    I have added an XPM file to a symbol view and it generated everything correctly. However, I would like to hide some lines that appear there, made um of characters.
    Each figure seems to be a group of smaller groups of objects. So if I want to remove a line, I can't since it will delete the full group.
    For example, the label "out" is shown as:
    out
    Is there a way to delete/hide these vertical lines/characters ?
    Thanks in advance.
    Best regards,
    Pedro
    Andrew Beckett over 5 years ago in reply to Pedro Cardoso
    Pedro,
    I don't really understand what you're saying. It might be easier if I contact you directly and deal with this as a support case - I think you're based the UK - is that correct? If so, I've found you in our support system and I can contact you directly.
  • Pedro Cardoso
    Thanks for the reply.
    Yes, please contact me directly. That would be very nice.
    Cheers,
    Pedro
