  3. How to Annotate the results into the schematic which is...
  • Views 18436
How to Annotate the results into the schematic which is opened in new Tab
fatcat1206
fatcat1206 over 10 years ago
Hi, All
I watch the video "Result Annotation Flow Enhancement in Virtuoso (Video)".
In the video, when annotating the results, a new schematic has been opened in a new tab in the ADE XL.
But I cannot do it within our design environment.
All the results are annotated in the existing schematic. Besides, the information on the lower right corner of the schematic window does not reflect where the results come from.
I assume there is some environment variable control the output location of annotation, does anyone know how to change the setup.
Best Regards
Yi
    Yi,
    To open the schematic in a tab, go over the test name in ADE XL and do Right Mouse Button (i.e. the context menu) -> Open Design in Tab.
    There's nothing special where you need to tell it where to annotate.
    Which IC version are you using? Help->About in the CIW will tell you the exact subversion number - please report it here.
  • fatcat1206
    Hi Andrew
    Thank you for your reply.
    my IC version is: IC6.1.6-64b.500.7
    Thank you for mentioned the way to open the schematic in tab, unfortunately this is not what I observed in the video "Result Annotation Flow Enhancement in Virtuoso", time 4:45.
    in the video, when annotating a different results, a NEW schematic view opens AUTOMATICALLY.
    such automation is what I want.
    link to the video:
    http://support.cadence.com/wps/myportal/cos/!ut/p/a0/HY2xCsMgFEW_pUO2UjNXHEJcupeQZhHR1_QRfVo1hvx90ywXDufAZRMb2US64qwLBtLu4JcFiA5p8Uj3AS2EAWGDxGUwqwcqzz2CqH9xpZDMG3ThX3GWTduvuQSvHr2SkHGmpq32mI4olPNDSczR6f32Kd7xnIzYImdx6S4_s150QA!!/
    Best Regards
    Yi
    Hi Yi,
    That's exactly what it should do - if the schematic is not already open, it will open it. If this is not happening for you, please contact customer support.
