  3. test vector creation for ATE
  • Views 19235
apple419
apple419 over 10 years ago
  My question is how to create the vector file used in ATE tester? I am running mixed signal simulations in ADE (virtuoso 615). I know I can use vector file to define my input stimuli. But on the output side, I would like to let the simulation automatically create a output vector file which is then used on the ATE tester.
   This is my first time dealing with test vector creation. Could anyone give some help! Thanks!!!
    I would imagine this rather depends on what your tester is expecting. I would suggest contacting customer support so that we can talk through your requirements in a bit more detail.
  • apple419
    Andrew,
      Thanks for quick response.
      The ATE I used expects a text file. Below is an example. Assume there are four digital signals in the design, signal1/2 out1/2.
    ----------------- example vector file --------------
    signal1  signal2   out1   out2
    0s           0  0  0  0
    1.1us      0  1  0  1
    2.5us      1  1   1  0
    100us     1  0  0  1
    --------------------- end of file --------------------------
        Basically what I need is this. Let simulator monitor those signals. Whenever there is a change to any one of these digital signals, write to the file with the format shown above.
    Probably the simplest is to use Simvision to export the data to CSV (File->Export in Simvision) and then write a script to munge the data into the format you want. The CSV will be close (apart from the commas) - mainly it's a matter of changing the time units in the first column. Even that you can mostly do with the Advanced CSV Options where you can change the time units to "s":
    SimTime,PLL_160MHZ_sim.I3.FBCLK,PLL_160MHZ_sim.I3.\5MHz_CLK
    0,0,0
    0.000000000068,0,1
    0.000000040068,0,0
    0.00000010761341,1,0
    0.00000011996932,0,0
    0.000000200068,0,1
    0.000000240068,0,0
    0.000000400068,0,1
    0.000000440068,0,0
    0.000000600068,0,1
    0.000000640068,0,0
    0.00000065492876,1,0
    0.00000065882769,0,0
    0.000000800068,0,1
    0.000000840068,0,0
    0.000001,0,0
  • apple419
    Andrew,
      I figured a way to create test vectors I need.  A verilog module can be created to write the desired signals to a file. The format can then be controlled.  To do so a strobe signal is needed to synchronize the writing.
    Below is the module:
    module tv_gen(in1, in2, strobe );
    input in1, in2, strobe;
    integer f;
    initial begin
    f = $fopen ("tv.txt", "w");
    #20000
    $fclose(f);
    $finish;
    end
    always @(posedge strobe)
    $fwrite (f, "%5dns %b%b%b\n", $time, in1, in2, strobe);
    endmodule
