  3. ams license queuing
  • Views 17449
ams license queuing
analogcad2
analogcad2 over 10 years ago
Hi All,
We have license token limit per user at our organization. So when I hit my token limit, I receive below error:
Trying to check out license...
AMS_Designer_Verification 14.20 - Failed
Virtuoso_Multi_mode_Simulation 14.10 - Failed
ncsim: *F,NOLICN: Unable to checkout license for the simulation. (flag - 18) 'lic_error -87'.
However instead of simulation failure, I would like to queue licenses until they are available.
I have already added below argument in ADE options form (additional argument field):
-licq -spectre_args "+lqt 0"
But above option seems to queue only Spectre licenses for me. For ams it directly fails and reports above mentioned error.
Is there any other options I need to use along with above argument? Any help would be highly appreciated!
Sandeep
    Hi Sandeep,
    Which subversion of irun are  you using? (i.e. what does "irun -version" return?). I found CCR 1510624 which says that it was broken for a while and appears to have been fixed in INCISIVE 14.2 s024 and INCISIVE 15.1 s011. That's of course assuming that you're seeing the same thing.
  • analogcad2
    Hi Andrew, I have tried 15.10-p001 and 14.20-s008 so far.
  • analogcad2
    Are these incisive versions released yet?
    Whoops - I'd not checked that. The fix was quite recent. The 15.1 version is available, but the 14.2 latest version is still s023 - I think it (s024) should be available soon though.
  • Sandeep4386
    Sandeep4386 over 10 years ago
    I'm having issues downloading INCISIV15.10.011. I tried multiple times but it gets stuck between 15-17% every time. Will work with local Cadence support team to figure this out.
