  3. Generating a current waveform in Cadence
  • Views 16053
BaaB
BaaB over 10 years ago
I am having a problem in generating a current waveform as the picture below.
Is there an easy way to do it in Cadence? Thanks!
    Of course - this is a simple PWL source:
    which produces this current output:
    You'll need to ensure you have finite rise times (not 0) but you can specify whatever you like here. You can also specify the piece-wise information in an external file and read that from the isource component too.
  • BaaB
    Yeah! Thanks a lot. I will try it now.
