  3. How can I edit the purpose of Pcell'Layers
  • Views 2052
tahm
tahm over 10 years ago
I am using TSMC18 with Cadence IC6, and when I flat the pcell (for instance nmos2V) as follow: Edit -» Hierarchy -» flatten. I have my layer's Diff and my layer's metal with Rectangle Pin's purpose. I want to change it to rectangle without pin.
How can I change the purpose of layers of pcell?
Mohammed Tahir
    Hi Mohammed,
    Your question is a bit unclear. If you're asking about how to change the purpose of the layers within the PCell without flattening it, then the simple answer is that you can't unless you redefine the PCell. Since you don't have the source code for that, you can't do so unless you re-implement it yourself.
    That said, why does this matter? It seems a bit strange to want to do this - what problem are you actually trying to solve?
  • tahm
    Hi Andrew, Yes, I was asking about how to change the purpose of the layers within the PCell without flattening it. Now I want to use a function that flatten the PCell and change some layers to the purpose I want to use. The problem that i am actually trying to solve is : - When I flatten my PCell, some layers are for instance in Rectangle Pin Properties and with layer in "metal1" drawing, and , I want those layers with Rectangle Properties and with layer in "metal1" drawing (i.e without Pin). Can I have a model of a function that can do this ( flatten a pcell and change the purpose of layers)? Regards, Mohammed
    Assuming I've understood what you're asking (which is a bit difficult, because it's really unclear), you simply need to turn off the option when flattening called "Preserve Pins". This is off by default, so you must have turned it on. Note this is nothing to do with changing the "purpose" of layers at all - it's to do with whether it's a pin object or not.
