  3. Script Skill: copy layers in the layout view
  • Views 17590
tahm
tahm over 10 years ago
When I flatten my PCell, and when I show the properties of some layers ( with Q) I have in the title of the window of properties " Edit Rectangle Pin Properties" and the layer in "Diff" "Drawing": so the layer is in Pin. I don't want those layers in "Rectangle Pin Properties " , I just want it in "Rectangle properties" only and because I need to use my PCell without flattening it : I need a script skill that search in my layout view the layers in Rectangle Pin "properties", make a copy of those layers in the same positions with only Rectangle (without Pin ) Property and in the same layer (Drawing) ( for example I want where there is A rectangle Pin with layer in Diff drw, A rectangle with layer in Diff drw)
By hoping to have been clear, thank you,
Mohammed,
    Why did you ask the same question again in a new thread? Was my answer to your other question not clear enough:
    I suggested turning off the "Preserve Pins" checkbox when you flatten the pcell. That will stop it being created as a pin.
  • tahm
    It is not the same question : I don't want to flatten my PCell, i have flatenned my PCell for debugging. I need here a script skill that search in my layout view the layers in "Rectangle Pin properties", make a copy of those layers in the same positions and with the same dimension with only "Rectangle (without Pin ) Property" and in the same layer (Drawing) ( for example I want where there is a layer in "Rectangle Pin with layer in Diff drw, A layer in "Rectangle with layer in Diff drw).
    Mohammed
    Hi Mohammed,
    I'm running out of patience here. You are asking questions where you are talking about flattening pcells, then say you don't want to flatten the pcells. Your questions are very unclear and I cannot see what you're trying to do or why you need to do this. For a start, there is no physical reason why having a shape which is both a pin and a non-pin in the same place on the same layer-purpose is needed. If you had got something as a pin that you didn't want as a pin, then you could solve that by not preserving the pins during the flatten (but now you say you don't want to flatten the pin).
    As my final word on this thread, if you want to covert pin figures into non-pin figures, then do this:
    foreach(shape cv~>shapes when(shape~>pin dbDeleteObject(shape~>pin)))
    foreach(term cv~>terminals unless(term~>pins dbDeleteObject(term)))
    If you're trying to propagate shapes from the pins on an instance to the top level (I am wondering if this is what you're trying to do - although I can't see why you would need to do this), then you could do:
    inst=car(geGetSelSet()) ; select the instance you want to propagate the pins from
    foreach(term inst~>master~>terminals
      foreach(pin term~>pins
        foreach(fig pin~>figs
          dbCopyFig(fig inst~>cellView inst~>transform)
    Anyway, enough of guesses as to what on earth you're doing. Good luck, as this is my final word on this as I can't expend more time trying to interpret what you're asking.
