  3. Query:
  • Views 14651
Query:
Alisha
Alisha over 10 years ago
Hi ,
I am working on a low voltage low power circuit and I have given an input voltage -Vin+Vtn to one of the NMOS transistors to realize desired function. I am getting desired results after simulating it on Cadence spectre.
My query is about the fabrication. Can I send my circuit to fabrication  lab as one of the input is comination of Vin and Vtn (threshold voltage). Will it create any issue or such inputs are acceptable.
Alisha
  • Quek
    Quek over 10 years ago
    Hi Alisha
    I think you can send any design for fabrication as long as it satisfies the following conditions:
    - PDK comes from an actual foundry and not a fictitious foundry such as Cadence generic PDK
    - Passes all DRC rules required by the foundry
    - Passes LVS check
    - Expected results are obtained from simulation using foundry models
    - Suitable chip package has been chosen
    Perhaps you might want to discuss more about your concerns with your supervisor, manager, etc.
    Best regards
    Quek
