  3. Hierarchical copy
  • Views 22626
Hierarchical copy
asetji
asetji over 10 years ago
Aim:
I am trying to copy a top cell(say TOP) from a library(Lib A) to another library(Lib B). Cells in library "Lib A" contains reference to cells from another library say "Lib C".  My aim is to make a top cell in Lib C which is self-referenced i.e., i don't want any cell being referred from "Lib C" or "Lib A". Furthermore, there are some common cells between "Lib A" and "Lib C", they are identical in all ways and I don't care which one gets copied as long as the reference is to "Lib B"
Problem: I am using copy wizard from Library manager, I select Hierarchical copy. I enter Top Library name as "Lib A", Top Cell as "TOP", views to copy as "*". In the skip libraries I add list of libraries I do want reference to say "analogLib", my pdk etc. In destination library I put "Lib B". I check the update instance box and select "of new copies only. After selecting "generate copy list", I clock apply and I get a list of "copy problems".  The problem is for the cells which are present in both "Lib A" and "Lib C".
1) Pressing "Overwrite All" doesn't do anything.
2) If i manually select "copy anyway" for all the conflicts and go back to the copy wizard page and click OK, it just again throws the same page again.
3) If I click "Fix Errors" then the conflicting cells are renamed and the references are changed to the renamed version, which I don't want.
4) If i select "don't copy" from say "Lib C" then conflicts are resolved but as expected, when I check in "Lib B", i do the reference to "Lib C" for the conflicted cells, again this is not what I want.
I have tried the normal copy form too, but the results are same. So, what procedure shall I use, so that I don't have to manually fix the "Lib B".
I have checked a similar  previous forum post " but there the problem was with views and again there was no solution.
BR
alok
  • Frank Wiedmann
    Frank Wiedmann over 10 years ago
    First, perform your option 4). After that, in the Library Manager select Edit -> Rename Reference Library and select: In Library "Lib B" Rename Instances From Library "Lib C" To Library "Lib B".
    It ought to be possible to do this directly with either the normal copy or copy wizard, but Frank's suggestion is a pragmatic approach which might be simpler... (I don't have time to work through what you said to check at the moment). Andrew
  • asetji
    thanks, it worked.
